Causes of PADM Malfunction
Sweiya
Porsche 911/718 models frequently experience PADM malfunctions.
Do you know why this happens?
As an auto repair shop technician, let me explain.
Generally speaking, Porsche's dynamic engine mounts are unlikely to have issues such as housing damage or magnetic fluid deterioration, so the problem is most likely with the sensor. As a key component of the sensor, the chip's fixing method is particularly critical. Porsche uses an adhesive bonding method for the chip, which makes it prone to falling off under high-pressure and high-temperature conditions, thus causing malfunctions.
Therefore, if a PADM malfunction occurs, the first thing to try is replacing the sensor rather than replacing the dynamic engine mount.
Sensors like this one not only meet OEM-level calibration standards but also adopt a mechanical pin fixation design for the chip, which greatly enhances its stability. What's more, it features a plug-and-play design with no software debugging required, significantly reducing the difficulty of replacement and allowing car owners to perform the repair by themselves at home.
