Let’s take a look at five things you should look out for in a fuel station, you might find some a little bit weird, but that’s the main fact.
The effective and the simplest or easiest way of creating illegal gains is the adulteration of fuel. After a series of fractional distillations from crude oil, fuel happens to be one of the products gotten from it. So some petrol dealers contaminate the fuel by adding some end product from crude oil residues like Naphtha.
Well, let's look at what to avoid and do while you are at the station.
First, let's learn to do the right thing to do. It's advisable to always turn off your engine completely before fueling. There are many reasons why you would want to do this.
One of such reasons is because it might cause an explosion and set the place ablaze. Therefore, Nigerians especially take this thing for granted until it has happened to one person.
Now, your mobile phones. Mobile phones emit radiation and hence cause fire outbreaks. Nigerians can relate to this; they would want to pick calls in that environment because they have not seen it explode, and they would often say " nothing dey happen".
Prevention is better than cure. The fuel station is not a place for making calls, and you should switch off your phone.
You wouldn't want to play with your health, so please try not to bring anything like cigarettes and matches, which could ignite a fire at the fueling station. You would like to return home safely to your lovely family and friends. Drive safely.
Read on five things you should know to avoid being defrauded in a Nigerian fuel station.
1. The unnecessary joviality
Fuel station scams are not new anymore! Although the attendants in these pump stations receive meagre income, especially in Nigeria, it is not a reason to defraud.
But any attendant that can be smart can make more money out of it by cheating customers by merely acting jovial and stealing your attention from the meter and dispenser!
2. The meter
When a petrol attendant resumes work in the morning, he takes the reading on the meter and the fuel dispenser, the opening meter. After the sales for the day by the attendant, they return to the manager with the money they sold while taking the rest home. Watch out for registered fuel stations. Many fuel stations reset their meters!
3. The oh-sorry trick
Attendants can scam you using the forgetful trick by nodding to particular music or doing something else when you request a fill-up (for example). They will knowingly put a particular litre or amount, then pretend they didn't hear you say to fill up.
When you reprimand and correct them, they will apologize and attribute it to forgetfulness.
Now here's the trick: instead of them to reset and start over, they click the recall button and continue, but you'll have to pay double. The “recall” helps an attendant recall the last ten purchases. The fraudulent ones can use it to defraud you!
They can recall an old purchase, say ₦2000, and begin from there to serve you for a deal of ₦5000. So you'll only get ₦3000 worth of fuel but pay ₦5000.
4. Always observe the nozzle (fuel dispenser)
When the nozzle is hung properly, it resets to the default; zero. But when not hung properly, they reserve your fuel there to use to sell to others. Also, please note this, longer nozzles automatically reserves your fuel, and it goes back to the engine -- enough fuel for them! E shock you?
5. The please-fill-up people
Taking advantage of people requesting a fill-up is very easy for a fraudulent attendant. They may pump air of ₦3000 for you and fuel of ₦10000. You'll hardly notice if you aren't smart!
I understand this post came as a shocker, but you can outsmart them if you come down from your car and watch everything. So even when you are buying in a gallon, don't be carried away by anything.
Source: https://www.nopremiumtears.com.ng/2021/08/five-things-you-should-know-to-avoid.html
2. The meter
