Method of lubrication of transmission units
Afo
21
Failure of a gear can have an enormous impact. These components must be lubricated properly and well maintained to achieve a long life. Lubrication is essential for the proper functioning of the gearboxes.
Adequate levels of lubrication benefit a gearbox by lubricating the teeth and removing heat generated from operations. Lubricant is also used on the various bearings inside the gearbox. Adequately lubricating these elements will result in high mechanical efficiency, reliability, low maintenance, and longer lifespan. The three major methods of lubrication known are grease, splash, and spray.
