Whenever the P2716 error code gets recorded on the ECU of any Toyota or Lexus vehicle, which triggers a check engine light on the vehicle's dashboard, a simple solution could be to drain and replace its transmission fluid with an appropriate/recommended one.
Please share other likely solutions to the error code you have used to fix the error if you have anyone.
