Sometimes, the seal of ones car's AC compressor could go bad while
the compressor is still good. The effect of a bad seal will make one to
be frequently topping up the gas of ones AC and the compressor will
as well be getting hotter than normal.
To fix this, the compressor will need to be removed and its seal replaced.
But the problem is actually with replacing with the seal that will work for
long time. Going for aftermarket seal could end up costing one much
time and money in the long run, which is the reason I do recommend one
replaces with OEM seal.
Getting OEM seal for ones car's AC compressor in ones locality could be
tasking, that ones only option would be importing it. Best solution is for
one to get another compressor either brand new or used to if one could
afford the option.
afford the option.
