TOP 8 reasons to buy Launch CRP129E
1. CRP129E one-click update and free lifetime.
2. Fast VIN autodetect, Support Wifi contact
3. Automatically generate and upload diagnostic reports
4.Supports 5 special reset functions: EPB/Oil/SAS/ ETS/TPMS reset
5. Support Multi-Protocols: OBDII, EOBD, JOBD, KOBD
6. Support Multi-language: English, Spanish, French, German, Italian, Russian, Japanese, Korean, Portuguese
?7. Supports 57 car brands.
8. 5'inch Android Touch Screen, Easy to operate
Introduction :
Creader Professional 129E is an innovative evolutionary solution for passenger car diagnosis. It inherits from LAUNCH's advanced diagnosing technology and is characterized by covering a wide range of vehicles, featuring powerful functions, and providing precise test results.
CRP129E support all ten models of the OBDII test for a complete diagnosis.CRP 129E also supports the system diagnosis of ABS.SRS, ENG and AT system. and 5special reset functions.
1. Smart(Auto-Detect) Diagnosis: Once the tool and the vehicle are correctly connected, the system starts the auto-detect process. Once the whole process is successfully finished, a diagnostic report will be automatically generated and
sent to your email box (if bound).
2. Manual Diagnosis: If Auto-Detect failure occurs, manual diagnosis is also available. Diagnosis functions include: Version Information, Read DTCs, Clear DTCs and Read Data Stream (supports three display modes: Value, Graph
and Merged).
3. OBD II Diagnosis: 10 modes of OBD II test are supported, including EVAP, O2 Sensor, I/M Readiness, MIL Status, VIN Info, and Onboard monitors testing etc.
4. 5 Special Functions: Frequently used maintenance and reset items including :
Oil lamp reset; Oil Reset Service allows you to reset a new calculation of the Engine Oil Life system once changed the oil.
Electronic parking brake reset; EPB service is essential in maintaining the electronic braking system's safety and efficiency.
Steering angle calibration; SAS service helps clear the fault steering angle sensor memories and plays a vital role in the steering angle sensor calibration.
Tire pressure monitor system reset; TPMS service makes sense in displaying sensor IDs from the vehicle's ECU, inputting TPMS sensor replacement IDs and testing sensors.
Electronic throttle position reset; After the engine works for a long time, there will be severe carbon deposition in the throttle, affecting the intake air. As a result, after cleaning or replacing the throttle, the throttle opening can not match the original computer. This lets the computer enter the throttle learning state so that the automobile computer can re-match the throttle opening.
5. One-click Update: Let you update your diagnostic software and APK online.
6. Diagnostic History: This function provides quick access to the tested vehicles. Users can choose to view the test report or resume from the last operation without the necessity of starting from scratch.
7. Diagnostic Feedback: Use this option to submit the vehicle issue to us for analysis and troubleshooting.
8. DTC Library: This allows you to retrieve the definition of the diagnostic trouble code from the extensive DTC database.
9. Displays battery real-time voltage once properly connected to the vehicle.
Supported Car Brands :
Lexus, Demo, Abarth, ACURA, BUGATTI, Alfa Romeo, Audi, BMW, Bugatti, Cadillac, Chevrolet, Chrysler, Citroen, DACIA, Daewoo, Euro Ford, Fiat, Ford, GM, Honda, Hyundai, Infiniti, JAGUAR, Jeep, Kia, Lancia, Landrover, Mazda, Mercedes, Nissan, Nissangtr, Opel, Peugeot, Porsche, Renault, SAAB, Seat, Skoda, Smart, Sprinter, Toyota, Vauxhall, Volvo, VW, etc.
Technical Specifications:
• Screen: 5" Touch Screen
• RAM: 1G
• ROM: 8GB
• Battery: 4000mAh rechargeable Li-battery
• OBD II input voltage range: 9~18V
• Charging via: DC 5V charging cable or Diagnostic cable through connection to vehicle's DLC
• Dimension: 228mm x 125mm x 34.5mm
• Working temperature: -10 to 50°C (14 to 122 F°)
• Storage temperature: -20 to 70°C (-4 to 158 F°)
Packing List :
1. Creader Professional 129E handset
2. OBD II diagnostic cable
3. DC 5V charging cable
4. User manual
5. Carrying bag
