TPMS stands for Tyre Pressure Monitoring System, which helps to monitor the psi in the tyres of most vehicles. It usually turns on when;
1. The psi in any of the tyres is low
2. The battery of any TPMS sensors is down, or if any of the sensors is longer good.
3. The TPMS system needs what we refer to as relearning.
It often leads to replacing bad TPMS sensors, of which OEM TPMS sensors don't come cheap. But I have the good news of what an affordable yet working TPMS sensor once could get. It is
CGSULIT Tire Pressure Sensor, 315MHz 433MHz 2in1 Universal TPMS Sensor, Programmable Cloneable Wireless Tire Pressure Monitoring System Sensor Replacement for 98% OE Tire Sensor SAE Standard TS01
